Loss of power in higher rev range
135,000 MILES • 2.0L • 4 CYL • FWD • MANUAL
ROMANHATFIELD
When taking the car around 4000 rpm the traction control light comes on and it starts slowing down and can't do anything about it until you restart the car, however in 1st gear I did a racey start and changed gear at 5500 rpm but when I changed in to second as soon as it went to 4000 rpm it did it, the EPC light is always on, any ideas would be great, thanks
Apr 17, 2014 at 2:12 AM
EXOVCDS
  • 1,882 POSTS
Have the engine computer and the Abs module scanned for codes... that will guide you into the right direction.
Thomas
Apr 18, 2014 at 2:00 AM
ROMANHATFIELD
Thanks but I've been researching and I think I have narrowed the problem down to the mass air flow sensor that could be doing this because if the symptoms of it.
Apr 18, 2014 at 3:22 AM
EXOVCDS
  • 1,882 POSTS
Okie Dokie...
Apr 18, 2014 at 3:24 AM
