Losing power going uphill?
120,000 MILES • 3.5L • 6 CYL • 2WD • AUTOMATIC
JESSICA MERTENS
  • 68 POSTS
My car has been doing this for a while now, every time I am driving and i go up a hill it loses power, and I lose speed unless I hold the gas pedal all the way down pretty much. Now lately it's been kind of cutting out and/or missing, if I'm doing 60 it'll be driving nice and then it seems like for a split second it loses power or something. I've changed the spark plugs and cleaned the mass airflow sensor and the throttle positioning sensor and I'm not sure what it could be. Let me know your thoughts. thanks.
Oct 22, 2024 at 5:35 AM
  • 55,743 POSTS
It sounds like the catalytic converter is getting clogged, do you have a check engine light on? If so, let run the codes to see which ones are stored.
This guide can help as well, please go over it to see the possibilities:
https://www.2carpros.com/articles/engine-has-low-power-output
Please go over these guides and get back to us.
Oct 22, 2024 at 10:25 AM
JESSICA MERTENS
  • 68 POSTS
no check engine light on at all.
Oct 23, 2024 at 6:25 AM
  • 55,743 POSTS
Okay, did you go over the guides above? I would check the catalytic converter next. Here is a guide to help:
https://www.2carpros.com/articles/how-to-test-a-catalytic-converter
Please go over this guide and get back to us.
Oct 24, 2024 at 2:10 AM
