2001 Lincoln Town Car No Blower Motor
RAWLINGSMD
2001 linclon town car
all fuses good. Looking for location of relay.
Unit failed and then came back at differet time before it would not come on at all. Believe relay. Where is it and what am I looking for/
Mike
Feb 5, 2007 at 9:35 AM
BHUGG
  • 157 POSTS
Ford products, so I assume Lincoln are pretty much identical, have a fuse and a relay under the hood in a power distribution box. Look for a plastic box under the hood. There will most likely be a fuse and a blower relay.
The dash board controls use a relay under the dash. The actual power circuit for the fan comes from the box under the hood. The fuse/relay designations are often imprinted on the inside lid of the box. Or check your owners manual for the fuse and relay.
I have had to change 2 relays in the box on my Ford.
Good luck
Feb 20, 2007 at 1:47 AM
Suggested Repair
Check the under-hood power distribution box for the blower fuse and relay; labels are on the lid or in the owner's manual. Dashboard controls use a separate relay under the dash, while fan power comes from the under-hood box. If fuses are good, replace the blower relay.
Conversation Summary
The owner of a 2001 Lincoln Town Car says the blower motor failed intermittently and then stopped completely. All fuses test good, and they suspect the relay. The expert says Lincolns follow the Ford layout: look in the plastic power distribution box under the hood for the blower fuse and relay, identified on the lid or in the owner's manual. Dashboard controls use a relay under the dash, while the fan power circuit comes from the under-hood box. The expert has replaced relays in that box on a Ford.
