1985 Lincoln Town Car Won't Start
I am the owner of a 1985 lincoln town car. I just recently tried to start the car but it just wont do it. The engine turns over but it doesnt come to life. About a few months ago I cleaned out the fuel pump thinking it was the problem and it was. I did this again recently and well it just doesnt start. Any help will be really appreciated. Thanks.
Feb 23, 2007 at 7:42 AM
did you check for spark yet ??? ignition modules are know to fail on your vehicle
let me know
jim
let me know
jim
Feb 23, 2007 at 1:26 PM
thanks for ur reply i figured it could have been the spark. wasnt really sure tho but thanks. ill let u kno asap.
Feb 24, 2007 at 6:54 AM
If there is not spark, start checking the fuses. there is a fuse panel under the hood that has ignition and engine circuit fuses and some relays that could be bad. Check these out. Also check the fuses in the dash. There could be something effecting ignition there also.
If we help, let us know.
The forum is here to help and we want to know if we are helping.
Give us a vote if we deserve it.
Feb 25, 2007 at 3:21 AM
you guys were absolutely right.it was the fuse box. seems there is not electricity runnin thru. heres another question now that i kno wat the problem is how much will it cost to get it replaced. something that will last. thanks again.
Feb 27, 2007 at 10:19 AM
Great to hear that it is solved.
Feb 27, 2007 at 3:17 PM
Suggested Repair
Check for spark. If there is no spark, inspect the under-hood ignition and engine-circuit fuses and relays, plus the dash fuses. Ignition modules are also known to fail on this vehicle. The owner found no electricity through the fuse box, so repair or replace the fuse box and related circuits as needed.
Conversation Summary
The owner of a 1985 Lincoln Town Car said the engine cranks but will not start. Cleaning the fuel pump had fixed a similar problem months earlier, but doing so again did not help. Experts advised checking for spark, noting that ignition modules often fail, and inspecting under-hood and dash fuses and relays. The owner later confirmed the fuse box had no electricity running through it and asked about replacement cost, which was not answered.
