1987 Lincoln Town Car Idle Misfire
RAINHOPPERROO
  • 13 POSTS
I have a low idle misfire issue. either at low idle or low load I feel a slight miss every once in a while. its not enough to cause a major loss in HP but I want to get it resolved before I replace the cats and 02 sensors (cats arent working at full efficiency I registered 127 ppm HC during my last smog) though this might be part of the issue.
here is a list of things I have done so far to resolve the misfire.
tuneup
plugs
cap
wires
rotor
timing set properly and tested
fuel injectors cleaned (professionally)
seafoam in the crank case (helps free up lifters that might be stuck)
checked EGR
checked for codes, none present
new temp sensors (3)
coolant air and engine
fuel injector cleaner aditive for extra measure
inspected for maniforld leaks (carb cleaner around gaskets)
block sniffer, checking for exhaust in the radiator, none found (blue liquid)
inspected radiator at operating temp for signs of head gasket seepage (fizzing or bubbling)
inspected oil for signs of coolant leakage
now once under a good load the problem disappears, I've not reinspected the plugs but the last time I ha this issue the plugs looked fine (another 87 but in a non emissions state) and the right bank is a pain to get to so I've been putting it off.
This car is low mileage, 93,000 original has the 302 efi v8 engine and the only TSB that shows was for the sensor on the manifold which I checked and replaced. (made a little diffrence in overall driveability but nothing for the misfire)
I was a mechanic (apprentice with 2 certs) so working my way around an engine is easy to do, I am willing to try some of the more unorthadox techniques as I am familiar with the safety and risk. but I need to track this down before I replace those cats, I dont want to frag them again and still not have a solution. those arent fun to replace ^_^
Jan 15, 2007 at 10:47 AM
SERVICE WRITER
  • 9,123 POSTS
clean your maf sensor.
It seems that a "missing" engine culprit is actually the computer's sensor inside the Mass Air Flow Sensor (MAF). It eventually just gets a little dirty or builds up its own patina in the filament wires. A dirty or slightly patinated filament will send the wrong air reading to the computer, saying it is getting more air than it really is and the computer will tell the EFI to send in the wrong mix of fuel, thus, the bogging. The patina seems to form faster if you live in a damp climate. If you have had bogging or missing or idle spots, about every 25K miles plan on this quick cleaning job:
When your engine is cool, remove the wiring clip from the side of the black plastic sensor part of the MAF aluminum body. To remove the MAF interior sensor wire, you will need a Security Star (Size T15 or T20) screwdriver or screwdriver bit for a power screwdriver. Remove the two security star-head screws and carefully remove the sensor. You will see the two sensor filaments…they look almost like the filaments on a light bulb. Carefully spray the filaments with an O2 safe carburetor cleaner, such as Gumout. Let it dry thoroughly. I help mine along with a careful blast or two of canned dry air. While it is drying carefully wipe the aluminum mount surface of the MAF body if there is any dust there, but be careful not to get dust in the mount hole. When the sensor is dry, replace the sensor back in the MAF body and secure with the security star-head screws. These don't need to be torqued down, just simply hand tight. Replace the wiring clip. Then start up your engine.
Jan 15, 2007 at 10:51 AM
RAINHOPPERROO
  • 13 POSTS
Unfortunately this town car does not have a MAF sensor. this was one of a few years where the 302 went on a MAP sensor only. thanks for the heads up, I wish it was that easy.
Jan 15, 2007 at 10:56 AM
SERVICE WRITER
  • 9,123 POSTS
:oops: I thought it was funny you would have overlooked it. IT seemed like you were pretty thorough.
If it's too good to be true it probably is.
Jan 15, 2007 at 11:56 AM
RAINHOPPERROO
  • 13 POSTS
it is definately ok =) It was part of fords blunder years. I myself was caught by the dual oil drains in the beginning. big mess that was =) I appreciate the quick response though. ^_^
Jan 15, 2007 at 1:14 PM
SERVICE WRITER
  • 9,123 POSTS
That gave me a flashback :shock:
It is said that engineers are ex-wives of mechanics.
There is a tsb on the fuel injector harnesses being loose. It says to pull the connector with apporiximatley 10 pounds of force to test it. If it comes off, replace it with pt # E7AZ-9D930-A.
How you estimate 10 pounds of force I'm not sure. Pull your bow back 1/6th of the way?
Jan 15, 2007 at 7:59 PM
RAINHOPPERROO
  • 13 POSTS
I dont remember that TSB. *snickers* probably why I havent tried it yet. I will give it a shot today and post results after 6pm pst there is also something I have a small hunch on. Lincolns are tempermental sometimes. with the MAP sensor setup, if I deviate more than 10% from stock setup, she will run like crap, I am going to inspect for some vaccume leaks inside the cabin of the car.
Jan 16, 2007 at 12:55 AM
Suggested Repair
This MAP-only 302 does not use a MAF, so MAF cleaning does not apply. Check the fuel injector harness connectors per the TSB by pulling each with about 10 pounds of force; if a connector comes off, replace it with Ford part E7AZ-9D930-A. Also inspect for vacuum leaks, including inside the cabin.
Conversation Summary
The owner of a 1987 Lincoln Town Car with a 302 EFI reports an occasional low-idle or light-load misfire that disappears under load, along with elevated HC. A tune-up, injector cleaning, EGR and sensor checks, and leak tests found no codes. After noting the car uses MAP rather than MAF, the expert recommended testing the injector harness connectors per a TSB and replacing any that pull off. The owner also planned to check cabin vacuum leaks.
