1987 Lincoln Town Car engine stall/fluid leak on rebuilt en
V8 • 2WD • AUTOMATIC
Just paid to have engine and transmission rebuilt. On way home at stop light the car stalled. Started right back up and made it home fine. Called mechanic and he said to take it back in a few days since he is so busy. Also noticed I am leaking transmission fluid in driveway when all gaskets where supposed to be replaced. Shoul I be concernd or is this normal with a rebuild?
Apr 3, 2010 at 12:07 PM
CARADIODOC
  • 34,406 POSTS
Fluid leakage is never normal. Your mechanic will inspect the drivetrain to find the source of the leak. Depending on how fast the leakage is occurring, he will probably have to wash the area, then run the engine to see where the fluid is coming from. If the puddle left behind where you park is only a few inches in diameter, it is probably safe to drive for a few days, but try to keep the mileage as low as possible until the mechanic can look at it and advise you further.
caradiodoc
Apr 3, 2010 at 5:52 PM
