1996 Lincoln Continental No Start
B07078
my car is a 1996 lincoln continental signature model
v-8 2 door.
the car turns over but wont start.,after a while
it starts.but now it wont start at all. the mechanic
said it was my catylitic converters,but the catylitic
converter mechanic said that was not the problem.
WHY DOESNT MY CAR START.
THANKS FOR YOU KIND HELP :lol:
Oct 26, 2007 at 4:31 PM
BLACKOP555
  • 10,386 POSTS
i would like you to do two things for me. First check for spark. remove spark plug one and have it ground up against engine and check for BRIGHT BLUE sparks. Second i want you to preform a fuel pressure test at the fuel rail, you will need a fuel pressure testing guage. Post results also if you could have it scanned for trouble codes and post that could help speed up the process.
Oct 27, 2007 at 1:53 AM
Suggested Repair
Check for bright blue spark at a grounded spark plug, test fuel pressure at the fuel rail, and scan for trouble codes before replacing parts.
Conversation Summary
The owner of a 1996 Lincoln Continental says the engine cranks but will not start, after previously starting only after a delay. One mechanic blamed the catalytic converters, but a converter specialist disagreed. The expert recommended checking spark, testing fuel-rail pressure, and scanning for trouble codes.
