HOME
ASK A QUESTION
REPAIR GUIDES
BECOME A MEMBER
LOG IN
Login with Facebook
OR
Remember me
NOT A MEMBER?
FORGOT PASSWORD?
CONTACT US
PRIVACY POLICY
TERMS AND CONDITIONS
Home
Lincoln
Town Car
Climate Control
Heater
2000 Lincoln Town Car rear passenger heater
RHUTCH1
MEMBER
2000 LINCOLN TOWN CAR
the manual direction flow shutters are loose. I want to take the front off. Can you tell me how,so I don"t break something.
Thanks
D
Monday, May 5th, 2008 AT 3:54 PM
MERLIN2021
MECHANIC
Use a thin blade tool, a screwdriver, or similar tool, I happen to use a door trim tool get in the middle and pry over rotate and lift out!
Monday, May 5th, 2008 AT 4:34 PM
Please
login
or
register
to post a reply.
Related Heater Content
Extreme Temperatures From The Heater
My Car Has The Automatic Climate Control. When I Want Heat I Have To Set The Temperature To 90 Degrees. It Blows Out Air At 110 Degrees....
Asked by
randall729
4 IMAGES
1994
LINCOLN TOWN CAR
GUIDE
Heater
Once the engine has been started and has run long enough to warm up the hot coolant is transferred into the heater core which is located inside the passenger compartment via...
No Air Comes Out Not Even When I Turn On The Heater?
I Have A 2000 Licoln Towncar 4.6l V8. 253,000. When I Turn On My Ac I Can Hear It Come On, But No Air Comes Out Not Even When I Turn On The...
Asked by
mcmyanks
LINCOLN TOWN CAR
My Climate Control Stopped Working?
I Have No Power To My Climate Control Instrument Panel. What Would Cause This And How Do I Fix It?
Asked by
Joyce Farley Smith
13 IMAGES
2000
LINCOLN TOWN CAR
Climate Control Module Not Getting Power
I Am Still Not Getting Power To The Climate Control Module In The Center Of Console After Replacing The Unit And Checking All The Fuses. Are...
Asked by
gordie4659
2000
LINCOLN TOWN CAR
2000 Lincoln Town Car Blower Fan Varies By Itself
The Blower Fan On Vent Goes Down And Up By Itself Once It Is Turned On. Example: If The On Vent Is Turned On And The Blower Fan Set At The...
Asked by
Nicholasanthony
1 ANSWER
2000
LINCOLN TOWN CAR
VIEW MORE
Heater Not Working
Heater Not Working
Blend Door Actuator Replacement
