1994 Lincoln Town Car my car keeps shutting off and wont st
GIADOLL32
  • 1994 LINCOLN TOWN CAR
  • V8
  • 118 MILES
My car runs fine fluids are fine car has no leaks however I can run it for a few days but once I park it will not start if I leave it for a few hours it will start again but once again once I shut it off it will not start unless it sits for awhile any ideas or suggestions on what it is or could be?
Wednesday, May 5th, 2010 AT 9:07 PM
Next time it won't start don't wait-Do below immediately.
Get a helper disconnect a sparkplug wire or 2 and ground it to the engine atleast 3/16 away from ground-have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel related problem, check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs, coil's resistances, distributor pick-up coil, ignition control module, cam and crank sensors and computer Note: If it doesn't apply disregard it
Thursday, May 6th, 2010 AT 12:19 AM
Related Engine Stall While Driving Content
