LINCOLN TOWNCAR CRUISE Control QUIT WHILE DRIVING TO WORK
132,000 MILES • 4.6L • V6 • RWD • AUTOMATIC
RANDALL729
  • 59 POSTS
I WAS DRIVING DOWN THE HIGHWAY TO WORK AND THE CRUISE CONTROL QUIT. I DO NOT KNOW WHY, EVERYTHING ELSE WAS FUNCTIONING AS NORMAL. THERE IS NO REASON FOR A FUSE TO BLOW AND I CHECKED THE FUSES, AND ALL SEEM OK. I HAVE HAD NO PROBLEM WITH THE CRUISE CONTROL IN THE PAST.
Jan 15, 2016 at 11:49 AM
HMAC300
  • 48,601 POSTS
check fuses 4 & 12 inside car as both work for cruise then have a pro look to see if clock spring inside steering column is working and check brake switch on brake line lowerleft rear of engine compartment as well as switch on pedal. it may be the amplifier not working as well. a test light can see if power is on both sides of brake switches if it is it will knock off the cruise.
Jan 15, 2016 at 10:29 PM
RANDALL729
  • 59 POSTS
Thank you. The fuses check out good. I found the brake switch as told and is connected. I am not sure about the clock spring or where to find the AMPLIFIER? I do know that the left rear brake light were not coming on but have since got them working. Maybe this had something to do with it? Randall
Feb 3, 2016 at 11:59 AM
HMAC300
  • 48,601 POSTS
no a pro will have to scan it for codes now and check the clock spring which is under the steering wheel
Feb 3, 2016 at 9:48 PM
RANDALL729
  • 59 POSTS
the car will be headed for the pro. needs front align. when they do this the steer wheel may have to be centered and would be a good time to check the spring at this time. i may post a comment about the solution.
Feb 4, 2016 at 8:26 AM
