1990 Lincoln Town Car Car acted posessed and now won't star
MR NIKON
  • 1990 LINCOLN TOWN CAR
  • V8
  • 167,000 MILES
I recently (2 months ago) replaced my battery, starter and starter solenoid. Yesturday, all of a sudden while I was pulling up to a red light, my stereo flicked on and off. It kept doing that, then finally just went off. The car seemed to miss a couple of beats in the process, acted almost like when you run outta gas (3/4 of a tank, though). Then it seemed to fix itself and was fine. When I came out of the store, it started up, radio and all. Then, after a quarter-mile it started sputtering again, and finally just died. Now when I try to start it, it sounds normal for the first 1/2 second or so, then I get this aweful ticking noise coming from the solenoid. First I replaced the Altinator (before I realized it was the solenoid making the noise). When I got the same symptoms, I then replaced the solenoid itself AFTER re-installing the old altinator. The altinator was only 3 years old, so I figured I'd put it back in if it wasn't that. So, back to square one. What else would cause this thing to act this way?
Thursday, February 28th, 2008 AT 8:32 PM
MERLIN2021
  • 17,250 POSTS
Use a volt meter on the battery and a hydrometer, if you can get one, the clicking while trying to start is indicative of a weak battery, Some lincolns require a fully charged battery, or it can kill even a new alternator. Have the alternator bench tested. Then check your battery cables at both ends. When you put it all back together, put pos(+) cable on first save neg(-) for last!
Friday, February 29th, 2008 AT 3:37 PM
MR NIKON
After taking your advice, I relooked at everything and sure enough, I wasn't getting a good ground. Ended up replacing the alternator, solenoid and ground cable, and now I'm back on the streets to photograph more beautiful models.
Thanks guys,
Jim
Sunday, March 9th, 2008 AT 3:44 PM
MERLIN2021
  • 17,250 POSTS
Your welcome Jim.
Monday, March 10th, 2008 AT 2:53 AM
