Hi jasmicall, Welcome to 2carpros and TY for the donation
I replaced the fuel filter, and then the car would not start at all. It cranks, but it wont turn over.
Lets do below and comeback with some results this will give me an idea what direction to take to knock this problem
Get a helper disconnect a sparkplug wire or 2 and ground it to the engine atleast 3/16 away from ground-have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel related problem, check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs, coil's resistances, distributor pick-up coil, ignition control module, cam and crank sensors and computer Note: If it doesn't apply disregard it
If both fuel and spark is present-check the valve and ignition timing, this will lead you to problems
with compression and valves opening and closing at the wrong time/broken or jumped timing
belt/chain
SPONSORED LINKS
Sunday, July 18th, 2010 AT 3:44 AM
