I have a 1998 Lincoln Continental 60,000 miles. The owner put brake fluid in the power steering system. I have changed the rack and pinion power steering hoses, power steering pump and the power steering reservoir. Now there seems to be a pressure problem. When the car idles by itself there is no sign of trouble. As soon as pressure is put on the steering wheel, the pressure pulls the steering wheel to the left. When it reaches a full left hand turn and you try to pull it back to the right, it blows a seal on what seems to be the pressure regulator. After the seal is blown, then it steers fine both ways. Please help. : :(
Dec 3, 2006 at 10:27 AM
