1993 Lincoln Continental won't start
M-AKEY
  • 1993 LINCOLN CONTINENTAL
Engine Performance problem
1993 Lincoln Continental 6 cyl Two Wheel Drive Automatic
developed water pump problem-changed water pump
now won't start Why?
Saturday, May 1st, 2010 AT 8:55 PM
BMRFIXIT
  • 19,053 POSTS
Check for what is missing
do you have spark
do you have fuel and fuel pressure
check injector pulse?
Recheck your work for disconnected wire or connector
Saturday, May 1st, 2010 AT 9:33 PM
M-AKEY
How do you check injector pulse
Saturday, May 1st, 2010 AT 11:10 PM
BMRFIXIT
  • 19,053 POSTS
Find an injector
unplug it, use a test light check for power with key on should have power on one of the wires
use a noid light in the plug instead of the injector
crank engine if have pulse light should blink as engine cranking
Sunday, May 2nd, 2010 AT 6:56 AM
