1990 Lincoln Continental My 1990 Lincoln Continental Cranks
WILLIAMDECKER
MEMBER
1990 LINCOLN CONTINENTAL
6 CYL
FWD
AUTOMATIC
68,371 MILES
My 1990 Lincoln Continental Cranks But Wont Start. What can be my problum I changed the modual and that dident help.
Tuesday, June 23rd, 2009 AT 8:54 PM
MECHANIC
Get a helper disconnect a sparkplug wire or 2 and ground it to the engine -have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel related problem, check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs, distributor pick-up coil, ignition control module, cam and crank sensors- Note: If it doesn't apply disregard it
SPONSORED LINKS
Tuesday, June 23rd, 2009 AT 9:14 PM
WILLIAMDECKER
MEMBER
There is no secondary spark from the coil. We have cheacked all fuses and they are all good.
Tuesday, June 23rd, 2009 AT 9:44 PM
MECHANIC
Check the rest that I've mentioned
Tuesday, June 23rd, 2009 AT 9:48 PM
WILLIAMDECKER
MEMBER
There is power to the primary on the coil. No secondary voltage to distribuor from coil and we just bought and put in a new ignition control modual. The cam and crank sensors are on the 4.6 engine I have a 3.8
Tuesday, June 23rd, 2009 AT 9:59 PM
WILLIAMDECKER
MEMBER
I cant figer it out
SPONSORED LINKS
Tuesday, June 23rd, 2009 AT 10:11 PM
MECHANIC
Check the coil's primary and secondary windings and also measure the distributor pick-up coil resistance and short to ground
