Limp mode loss of power
345,000 MILES • 1.7L • 4 CYL • 2WD • MANUAL
RICKY1986
When you turn the key on some times the battery light and engine light will flicker back and forth for about 3 seconds apart and 4 or 5 times,when the battery light is on for the 3 seconds. Car has all its power,rpm temperature gauge work also and the green key symbol is off too. when the engine light is on for the next 3 seconds it goes back to limp mode rpm, temperature gauge won’t work and the green key symbol flashes..it does that for about 4 times engine light always wins,not all the time they flicker back and forth. most of the time the engine light only goes on and stays on.it idles fine it doesn’t shut off.
Jun 19, 2021 at 6:00 PM
  • 110,251 POSTS
That sounds like a voltage-related issue. I need you to perform a simple test. Let's make sure the alternator is doing its job. Follow the directions in the following link. All you will need is a voltmeter or a multimeter. It's easy to do.
Next, if you haven't already, you should have the computer scanned to determine if there are any diagnostic trouble codes stored which could point us in the right direction. Here is a quick video showing how it's done:
https://youtu.be/b2IJGfImVvw
I realize most people don't own a scanner, but most parts stores will do it for you free of charge.
Try these things and let me know the results. If there are codes stored, let me know what they are.
Jun 20, 2021 at 2:25 PM
