Brake lights are not working
175,000 MILES • 3.6L • 6 CYL • AUTOMATIC
JOEDIAZ478
No brake lights at all.
Jul 11, 2021 at 5:22 PM
SQM
  • 6,383 POSTS
So did this just happened all of a sudden?
Typically when you have none of the lights come on when depressing the brake pedal, it is likely the cause of a faulty brake light switch. The brake light switch is located under the brake pedal.
Here is a helpful link that might be able to help you determine the issue:
https://www.2carpros.com/articles/brake-lights-not-working
Jul 12, 2021 at 12:57 AM
