1990 Lexus LS400 Intermittent No Start
LEXUS
JUST?_US
I have a 1990 lexus ls400, 160k,v8. the problem that I am having is that, every couple of weeks, it chooses not to start. I replaced the battery and the alternator. When i try to start it, at times, it will not turn over (doesn't make a sound). I can have it jumped and it will crank. It also takes about 2-3 seconds for it to crank when it does. I also changed the spark plugs. A friend told me that it was the starter that needed to be replaced. I was going to do so but I cannot find its location. HELP!!!!! Is this a starter malfunction and, if it is, where is it located in this particular car? I would be VERY greatful for any amount of assistance ... Thank You :!:
Oct 7, 2007 at 2:52 AM
MERLIN2021
  • 17,250 POSTS
Going by what I see in the mitchell books, unless you are a very good mechanic, have a shop do it. This model requires a lot of engine dissasembly to replace...and it may not even be the problem! The security system, neutral saftey switch, relays or wiring could be the problem.
https://images.2carpros.com/forum/automotive_pictures/62217_Starter_Removal_copy_1.jpg
All these parts must come off to get at the starter!
Oct 7, 2007 at 3:33 AM
LOSTINMARS
  • 222 POSTS
starter is in the "v" of the engine. yes i would have it checked by someone familiar with this model before going any further.
Oct 10, 2007 at 3:35 PM
Suggested Repair
Have a shop familiar with the LS400 diagnose the no-crank before replacing the starter. Check the security system, neutral safety switch, relays, and wiring. The starter sits in the V of the engine and requires substantial disassembly.
Conversation Summary
The owner of a 1990 Lexus LS400 reports an intermittent no-crank every few weeks after replacing the battery, alternator, and spark plugs. Jump-starting allows it to crank, and cranking can take 2-3 seconds. Experts say the starter is in the engine V and hard to access, but the security system, neutral safety switch, relays, or wiring may be at fault, so a shop familiar with the model should check it first.
