1993 Lexus LS400 Fuel Injection No Start
1993 LEXUS
2CP-ARCHIVES
  • 4,540 POSTS
Hi I think it is great to finally find a place to ask for another opinion from another Knowing Professional :D now onto my little problem:I am having a problem with a 1993 Lexus LS400 in regards to the fuel inj. sys.To start off when it came in it had 0# of compression in #8 so that heacd was removed to find a bad intake valve it was replaced and it was re-assembled,it has spark,it has a fuel pump and turns iover fine.Yet the fuel inj.sys.fails to function,thuogh it will start with a small shot of gumout though does not continue to run.PLEASE HELP :?
Mar 5, 2006 at 4:04 PM
PEPPERMRJ
  • 1,158 POSTS
You can hear the pump running? Fuses, wires, connections, check all. What sort of fuel pressure do you have? Clogged filter, fuel pressure regulator?
Good luck and let us know. :)
Mar 5, 2006 at 4:33 PM
Suggested Repair
Confirm the fuel pump is running, then check fuses, wiring, and connections. Measure fuel pressure and inspect for a clogged fuel filter or a faulty fuel pressure regulator.
Conversation Summary
A 1993 Lexus LS400 will not keep running after a cylinder head repair for a bad intake valve on cylinder 8. It has spark, cranks normally, and is said to have a fuel pump, but the fuel injection system does not sustain operation; it only starts briefly with starting fluid. The expert advises confirming the pump can be heard, checking fuses, wires, and connections, measuring fuel pressure, and considering a clogged filter or fuel pressure regulator.
