light blue smoke
LEXUS
ELLISMACK
lexus 92 ls400 v8 230k miles
smokes on start up and then clears, heavy smoke after setting up for a couple of hours, had it checked
codes stated mass air flow meter, and knock sensor
had air flow meter replaced , did not help. did not replace knock (expensive). noticed some black
reside in tail pipe. Any suggestions?
Feb 17, 2007 at 3:02 AM
SERVICE WRITER
  • 9,123 POSTS
sounds like its burning oil. Might want to bump up the oil viscosity a grade.
Feb 17, 2007 at 8:12 AM
KIN CHAN
  • 453 POSTS
blue smoke is oil
black smoke is running rich --> too much gas
white smoke is water or coolant in ur combustion chamber
i don't think the blue smoke have anythign to do with those 2 sensors ...when is cold ur cylinder head valve seals are hard ..cuz they make out of rubber..and ur car is high mielage..once it warms up it get soft so it seal up the oil dripping from the cylinder head to the combustion chambers ..make sense ? ...good luck man..
also..whenever ur car misfire ..ur engine runs unevenly make some engine noise ...knock sensor detected it ..generate a code thats all it is to it ...it just doing its job...ur code is knock sensor ..not knock sensor bad..it also can imply the computer is getting some abnormal signal that its outta a good operating range --> misfire!!
hey these guys here on this website are really good guys ...they let me come aboard to be part of their team...try to give em' some support if u think my answer worth anything ...thanx man...
Feb 20, 2007 at 12:58 AM
