2000 Lexus ES 300 Won't Idle
LEXUS
BIGGE31566
I have a 2000 lexus es 300 and the car would not start unless you gave it gas by the pedal a couple months ago a nd I changed the fuel filter and it started, bur a couple of weeks later it did the same thing . I tried this time of giving it gas again then it ran alright until now. Its doing the same thing except I can drive it by keeping the gas idled up and mashing the brake once you start driving it runs find but it would idle
Mar 2, 2007 at 10:05 PM
MERLIN2021
  • 17,250 POSTS
Last tune up? last fuel filter? check idle air controller.
Apr 2, 2007 at 12:46 PM
LOSTINMARS
  • 222 POSTS
clean the throttle body out real good. if that doesn't work most likely the idle air control valve is going bad. very common on toyota 3.0/3.3 fwd vehicles.
Apr 9, 2007 at 7:55 PM
Suggested Repair
Clean the throttle body thoroughly and check the idle air control valve, which commonly fails on these Toyota 3.0/3.3 FWD engines. Also confirm recent tune-up and fuel-filter service.
Conversation Summary
A 2000 Lexus ES 300 would not start or idle unless the throttle was held open, though it ran fine once driving. Replacing the fuel filter helped briefly, then the idle problem returned. Experts advised checking the last tune-up and fuel filter, cleaning the throttle body, and inspecting the idle air control valve.
