1997 Lexus ES 300 Tapping Noise
LEXUS
2CP-ARCHIVES
  • 4,540 POSTS
1997 Lexus ES 300 Mileage 177,000. I paid approximately $750 for a valve adjustment job approximately 2 1/2 years ago at a local Toyota dealership due to tapping noise. Upon completion of maintenance procedures, engine continued to make tapping noise. Two weeks ago, I took my vehicle to an authorized Lexus/Toyota repair shop and the technician informed me that my fuel injectors were causing this annoying tapping noise. The technician asked me to place my hand on the end of the fuel rail and I felt a vibration with the engine running.
Is it possible for the injectors to make a tapping noise? If injectors are defective should I attempt to repair with over the counter injector cleaners first or have technician replace defective injectors? Is it safe to purchase used injectors (from Ebay) or buy new injectors?
Nov 24, 2006 at 5:51 PM
2CARPRO JACK
  • 11,533 POSTS
When it comes to injectors, buy new.Yes the injectors are electrically controlled solenoids, they make a ticking noise. But the noise you hear could mean bad tappets, they may need to be replaced.
Nov 28, 2006 at 1:42 PM
2CP-ARCHIVES
  • 4,540 POSTS
[quote="2CarPro Jack"]When it comes to injectors, buy new.Yes the injectors are electrically controlled solenoids, they make a ticking noise. But the noise you hear could mean bad tappets, they may need to be replaced.
What are tappets and where are they located?
Dec 2, 2006 at 9:42 AM
Suggested Repair
If the injectors are faulty, replace them with new units rather than used ones. Injector ticking can be normal solenoid noise, so also have the tappets inspected and replaced if worn.
Conversation Summary
The owner of a 1997 Lexus ES 300 reports continued engine tapping after a prior valve adjustment. A shop blamed the fuel injectors after vibration was felt at the fuel rail. The expert says injectors normally tick because they are solenoids, recommends buying new injectors rather than used ones, and notes that bad tappets may instead need replacement. A follow-up asking what tappets are and where they are located was not answered.
