Reply Fuel Problem Maybe
LEXUS
BIGGE31566
I have a 2000 lexus es 300 and the car would not start unless you gave it gas by the pedal a couple months ago a nd I changed the fuel filter and it started, bur a couple of weeks later it did the same thing . I tried this time of giving it gas again then it ran alright until now. Its doing the same thing except I can drive it by keeping the gas idled up and mashing the brake once you start driving it runs find but it would idle
Mar 2, 2007 at 10:05 PM
MERLIN2021
  • 17,250 POSTS
Last tune up? last fuel filter? check idle air controller.
Apr 2, 2007 at 12:46 PM
LOSTINMARS
  • 222 POSTS
clean the throttle body out real good. if that doesn't work most likely the idle air control valve is going bad. very common on toyota 3.0/3.3 fwd vehicles.
Apr 9, 2007 at 7:55 PM
