1992 Lexus ES300 Overheats Fast
1992 LEXUS
PJWINSD
1992 lexus es300 approx 160K miles. Drove from San Diego to Murrieta, car sat for about 1.5 hours - drove one mile - car sat 30 minutes - drove approx 5 miles when car lost power/slowed down, then check engine light went on, seconds later all lights went on as car died. Coasted and stopped - steam coming out from both sides of hood. lifted hood and most coming from melted T connector near overflow. Let it cool off for hours & T connector replaced, added water, burped, but still hot. Replaced thermostat but still hot. Please advise - my car is in Murrieta and I live and work in San Diego and need help - What next? thanks!!!!!
Aug 24, 2006 at 8:05 AM
MIKEYBDMAN
  • 623 POSTS
[quote:ece62cf533="pjwinsd"]1992 lexus es300 approx 160K miles. Drove from San Diego to Murrieta, car sat for about 1.5 hours - drove one mile - car sat 30 minutes - drove approx 5 miles when car lost power/slowed down, then check engine light went on, seconds later all lights went on as car died. Coasted and stopped - steam coming out from both sides of hood. lifted hood and most coming from melted T connector near overflow. Let it cool off for hours & T connector replaced, added water, burped, but still hot. Replaced thermostat but still hot. Please advise - my car is in Murrieta and I live and work in San Diego and need help - What next? thanks!!!!![/quote:ece62cf533]
Does it overheat relaly fast, or does it slowy get hotter and hotter? If it is really fast, and the thermostat has been replaced, I would suspect a bad water pump, or an obstruction stopping water flow.
They make a flush'n fill kit from prestone that has adapters to install in the heater core hose that flushes the system. With the radiator hose disconnected at the thermostat, and the thermostat removed, when you apply water pressure to this adapter, you should get water flow from both directions. If one is not flowing, track down the obstruction. If the water flows both ways, I would suspect a bad water pump.
Make sure after servicing, you bleed the air from the system thru the bleed port.
Aug 24, 2006 at 8:22 AM
PJWINSD
[quote="Mikeybdman"][quote="pjwinsd"]1992 lexus es300 approx 160K miles. Drove from San Diego to Murrieta, car sat for about 1.5 hours - drove one mile - car sat 30 minutes - drove approx 5 miles when car lost power/slowed down, then check engine light went on, seconds later all lights went on as car died. Coasted and stopped - steam coming out from both sides of hood. lifted hood and most coming from melted T connector near overflow. Let it cool off for hours & T connector replaced, added water, burped, but still hot. Replaced thermostat but still hot. Please advise - my car is in Murrieta and I live and work in San Diego and need help - What next? thanks!!!!![/quote]
Make sure after servicing, you bleed the air from the system thru the bleed port.[/quote]
THANKS! It does get hot really fast! Thankyou Thankyou for your help!!
Aug 24, 2006 at 10:12 AM
PROBLEMS
i have a 1992 lexus ES300 and i need to replace the thermostat, but i cant find it. i looked on the top radiator hose and its not there so could someone please tell me where to look?? any help would be greatly appreciated!!!
Apr 26, 2007 at 7:25 AM
Suggested Repair
Because it overheats very quickly after the thermostat was replaced, check for a failed water pump or a blockage restricting coolant flow. With the thermostat removed, flush through the heater hose and confirm water flows both ways; if flow is good both ways, suspect the water pump. After service, bleed air through the bleed port.
Conversation Summary
A 1992 Lexus ES300 with about 160,000 miles overheated, lost power, and steamed after a drive, with a melted T-connector near the overflow. The owner replaced the connector and thermostat, added water, and burped the system, but it still got hot very quickly. The expert said rapid overheating points to a bad water pump or an obstruction, and recommended a flush-and-fill check of flow in both directions plus bleeding air. A later post asked where the thermostat is located but received no reply.
