1999 Lexus RX 300 Clicking on Turns
LEXUS
SPKULMOM
I have just purchased a 1999 Lexus rx 300, V6 with 92,000 miles. I noticed that when I make a turn, I hear a single clicking sound from the left.front of the car. This happens on left and right turns, tight or wide. The dealer told me this was normal "age" sounds. I think he is crazy. Could this be a bushing or boot problem or ??? Thanks alot!
Sep 12, 2007 at 9:22 PM
SERVICE WRITER
  • 9,123 POSTS
Sounds like a typical dealer salesman response. Something is happening. Noises can be a little challenging at times. If you have a wheel cover, take it off and drive it. That is the simplest thing to check. My next suspicion is the brake pad moving in the caliper bracket. Braking on a turn should cause the pad to not move and stop the clicking. Try that also. Cv joints or wheel bearings can click on turns when the are getting bad but typically it is only while making a left OR a right.
Sep 12, 2007 at 11:37 PM
Suggested Repair
Remove the wheel cover and test drive. If the click remains, check for a brake pad shifting in the caliper bracket by braking during a turn. If it continues, inspect the CV joints and wheel bearings, which more often click in only one turn direction.
Conversation Summary
The owner of a 1999 Lexus RX 300 with 92,000 miles hears a single click from the left front on both left and right turns. A dealer called it normal aging, but the expert disagrees and suggests checking the wheel cover, then brake-pad movement in the caliper, and finally CV joints or wheel bearings.
