1997 Lexus ES 300 Clicking Noise
Why don't you get it to another shop. Could be a valve/lifters/camshaft problem. Its considered a major repair if you have to remove the head. Somebody is pulling your leg on that 3K-don't say I didn't tell you.
I've been in dealers I know how they operate
Good Luck
Suggested Repair
Get a second opinion and start with an oil change or flush, then recheck the clicking, since dirty oil can make the small hydraulic lifters tick. If the noise remains, have the valvetrain inspected for lifter, rocker, valve, or camshaft problems. Compare quotes before approving head removal or considering an engine rebuild or replacement.
Conversation Summary
The owner of a 1997 Lexus ES 300 with 150,000 miles reports a clicking noise whenever the engine runs. A dealer blamed the valvetrain and quoted about $3000. One reply recommends another shop and says it could involve valves, lifters, or the camshaft, becoming a major repair if the head must be removed. Another suggests changing or flushing the oil first because the hydraulic lifters need clean oil, then rechecking the noise.
