2000 Other Lexus Models warning lights
2000 LEXUS
CLARKJ
Engine Mechanical problem
2000 Other Lexus Models 4 cyl Front Wheel Drive Automatic
what is the warining light mean?
ECT/PWR
Oct 12, 2008 at 3:05 AM
DOCFIXIT
  • 18,828 POSTS
Something to do with Engine Coolant Temp
Oct 12, 2008 at 7:29 AM
GREGDYER
  • 9 POSTS
The ECT light is for the electronically controlled transmission. This type of trans. has two modes, power or (pwr) and normal (nml). Located somewhere on the center console or dash will be a switch marked "ECT" throw the rocker one way and PWR illuminates, back the other way and "NML" will come on. Basically, power mode will delay shifts to a higher rpm and normal will go to the next gear much sooner, (lower rpm) for the same speed and throttle position.
Nov 3, 2008 at 2:17 AM
