Lexus Battery Light Stays On
LEXUS
JEFF BACKNER
My Battery light has been coming on when I drive my car for about a mile or two and then goes off, until today it just stayed on. I ordered a belt tensioner thinking it is slipping a little bit and/or my ALT is going bad But still check 13.8 volts from the Alt at the Battery not the back of the Alt. So I had to get a new battery tonight since I have been running on it for days but now my O/D light just started blinking on and off and my E-brake light has been coming on when I excel or stop quickly for months and I just thought it was a sensor going bad or loose, But now I wonder if I have a bigger electronical issue? Could this be two seperate issues all together? Or is there electronical problems that I am over looking?
Thank-You very much for listening!
Jeff B in Pittsburgh PA
Apr 25, 2007 at 1:34 PM
BESTBET777
  • 89 POSTS
Testing and repairing charging circuit needs to all be done at the same time. Test battery, starter, altenator and regulator and repair all same day. Any one piece can cause the otthers to go bad fast sometimes in less that a day.
Apr 26, 2007 at 1:02 PM
Suggested Repair
Test the battery, starter, alternator, and voltage regulator together, then repair every failed part the same day so one weak component does not quickly damage the others.
Conversation Summary
A Lexus owner reports the battery light coming on after a short drive and then staying on, with about 13.8 volts measured at the battery. After installing a new battery, the overdrive light began blinking, and the parking-brake light has been coming on during acceleration or hard stops. The expert advises testing the battery, starter, alternator, and regulator together and repairing all faults the same day.
