Battery
2017 LEXUS
100 MILES • 2.0L • 6 CYL • AWD • AUTOMATIC
SACHIGITA
Do I need to disconnect the battery when I go on vacation for four months as no one will be able to drive it?
May 2, 2017 at 10:49 PM
HMAC300
  • 48,601 POSTS
you should as there is always a slight draw on it from the electronics and that amount of time could draw it down to nothing. the most you will have to do is to reset security system to start and get radio code if yours is needed to make it work once more.
May 3, 2017 at 12:11 AM
