1993 Lexus LS 400 will not start
BLACKICE4LIFE
  • 1993 LEXUS LS 400
1993 Lexus LS 400 V8 Two Wheel Drive Automatic
having problem getting car to turn over. Had battery problem.
Tuesday, February 23rd, 2010 AT 10:34 PM
What is it doing? Cranking over and will not start or just won't crank at all/nothing/nada?
Wednesday, February 24th, 2010 AT 4:24 AM
BLACKICE4LIFE
It will almost start. It just will not run
Friday, February 26th, 2010 AT 8:24 AM
Get a helper disconnect a sparkplug wire or 2 and ground it to the engine at least 3/16 away from ground -have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel related problem, check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs, coil's resistances, distributor pick-up coil, ignition control module, cam and crank sensors and computer Note: If it doesn't apply disregard it.
Friday, February 26th, 2010 AT 1:54 PM
