1992 Lexus LS 400 Key in ignition will not start car.
NSHINGLES
  • 1992 LEXUS LS 400
  • V8
  • 18,900 MILES
I put the key in the ignition, you can hear the dinging and lights appear on dash. But when I try to turn the key it won't move. Called several locksmiths, no will touch it because it has too many small parts that could be wrong. Does anyone know why this happening and should this be happening? Can I just have another key made? According to lexus dealership it's not the key. So what is it?
Tuesday, June 24th, 2008 AT 6:46 PM
MARK FRIZZELL
  • 142 POSTS
Have u disconnected the battery or have had power loss, if so try unlocking the car door with the key first then try to start it. If not give a small tugg on the steering wheel at the same time and make sure it is in park all the way.
Saturday, July 19th, 2008 AT 1:31 PM
CARRIEDEVANE
  • 6 POSTS
THE DEALERSHIP TOLD ME THE SAME THING. BUT IT WAS THE KEY.I TOOK MY CHANCES AND SPENT THE 64 DOLLARS FOR A NEW KEY AND IT WORKED FINE. MY OLD ONE WAS JUST WORN DOWN TOO MUCH, IT WOULD STILL WORK THE DOOR LOCKS AND TRUNK BUT SAME AS YOU IT WOULD NOT TURN THE IGNITION. SO I WOULD SAY GO HAVE THE NEW KEY MADE.
Monday, September 15th, 2008 AT 7:07 PM
DOC1692
Mark, you were right on regarding the problem with my Lexus. I did as instructed and the car fired right up thanks for the assistance!
Saturday, May 6th, 2017 AT 10:08 AM
KEN L
  • MASTER CERTIFIED MECHANIC
  • 54,388 POSTS
Glad you could get it fixed, that kind of problem can be tough. Please use 2CarPros anytime we are here to help
Cheers, Ken
Monday, May 8th, 2017 AT 5:36 PM
