Lean code
ROBERT BROWN6
  • 17 POSTS
It has been acting up sense I put the new engine in.
Wednesday, June 13th, 2018 AT 2:14 AM
STEVE W.
  • 13,577 POSTS
Does it seem to run good except for the light? When you first installed it did it have all the emissions parts that you have eliminated, and it still did this or did you eliminate that when it went in? Still has the original converter design?
Wednesday, June 13th, 2018 AT 12:12 PM
ROBERT BROWN6
  • 17 POSTS
It has all part except smog pump stuff.
Wednesday, June 13th, 2018 AT 12:20 PM
ROBERT BROWN6
  • 17 POSTS
It runs a little rough until I give it more fuel.
Wednesday, June 13th, 2018 AT 12:22 PM
KEN L
  • MASTER CERTIFIED MECHANIC
  • 48,363 POSTS
Running rough is the issue anytime there is an engine miss you will get a lean code. I would start with a compression test to see if the engine is okay.
So we do not chase our tail.
Cheers, Ken
Sunday, June 17th, 2018 AT 10:59 AM
ROBERT BROWN6
  • 17 POSTS
It was the EGR valve. It runs good now. Thanks for the help.
Sunday, June 17th, 2018 AT 1:43 PM
STEVE W.
  • 13,577 POSTS
Glad to hear you found it. I think I mentioned the EGR somewhere along the line. Did pulling the vacuum line off change it or did you remove it and find it was damaged? Either way.
Thank you for using 2CarPros. Com Please return anytime with your automotive questions.
Sunday, June 17th, 2018 AT 1:49 PM
ROBERT BROWN6
  • 17 POSTS
I bought a new one.
Sunday, June 17th, 2018 AT 2:17 PM
