Leaking brown fluid under the engine
117,000 MILES • 4.2L • 6 CYL • 4WD • AUTOMATIC
ZACK.LYONS2326
Leaking brown fluid under the engine has a weird smell and when wet looks like a rainbow. the engine oil level is high.
Jun 13, 2019 at 4:59 AM
  • 110,248 POSTS
Welcome to 2CarPros.
What you described is oil. However, my concern is why the oil level is high in the engine. When you check the oil, does it have a fuel smell? Is there any evidence of a tan creamy substance in the oil?
If there is a fuel smell, we may have a problem with fuel pressure or a leaking injector. However, if you see a tan creamy substance, it may be coolant mixing with the oil as a result of a bad head gasket. Is there any white smoke from the exhaust?
Take a look through these links and let me know if anything seems to mirror what you are experiencing other than the oil leak.
https://www.2carpros.com/articles/excessive-smoke-coming-from-the-exhaust-pipe
https://www.2carpros.com/articles/coolantantifreeze-in-the-engine-oil
Also, when you check the oil, smell the oil on the stuck to see if it smells like gas.
Jun 13, 2019 at 5:17 AM
