1991 Land Rover Discovery Black Smoke
Post back. :)
Where are you located?
Replace air filter, fuel filter, PCV valve, and check for any vacuum hose leaks.
Might be all that is needed. Post back if not. good luck. :)
Suggested Repair
Replace the air filter and check the air inlet for restrictions. Replace the spark plugs, plug wires, and distributor cap and rotor if equipped. Replace the fuel filter and PCV valve, inspect vacuum hoses for leaks, and run a tank of fuel with injector cleaner. At this mileage, an oxygen sensor may also need replacement.
Conversation Summary
The owner of a 1991 Land Rover Discovery V8 with 166,000 km reports black smoke and wants a leaner mixture. The vehicle has never been serviced, has no check-engine light, and smokes more after hard starts. The expert said a fuel-injected engine offers little to tune and recommended ignition and intake service: plugs, wires, cap and rotor, air and fuel filters, PCV valve, a vacuum-leak check, injector cleaner, and possibly an oxygen sensor.
