1995 BMW 525i White Smoke
AJAY
I have 1995 BMW 525i and it is always giving off whit smoke. I noticed it does not overheat or anything like that. The outside temperature is 38deg F. All the other cars are running fine. Sometimes I smell collant inside the car but have been unable to find a wet spot in the car. Help.
Jan 22, 2006 at 7:01 AM
SOUTHCALIKING
  • 5 POSTS
white smoke is means water
black is oil
Jan 25, 2006 at 1:40 PM
2CARPRO BOB
  • 45 POSTS
White smoke when first started is normal. If white smoke continues you have an internal coolant leak, i.e., cracked head/blown head gasket. Black smoke is caused by a rich fuel condition. Blue smoke is caused by oil consumption. The smell of coolant inside your car is caused by a leaking heater core.
Feb 6, 2006 at 2:30 PM
Suggested Repair
If white smoke continues after startup, inspect for an internal coolant leak such as a blown head gasket or cracked cylinder head. A coolant smell inside the cabin indicates a leaking heater core, which should be checked and replaced if leaking.
Conversation Summary
The owner of a 1995 BMW 525i reports continuous white smoke without overheating and an occasional coolant smell inside the car with no visible wet spot. An expert explained that brief white smoke on a cold start can be normal, but ongoing white smoke indicates an internal coolant leak such as a cracked head or blown head gasket. The interior coolant smell was attributed to a leaking heater core.
