vehicle shudders and has no power once in gear
1995 FORD ASPIRE
75,616 MILES • 1.3L • 4 CYL • 2WD • AUTOMATIC
BUGGIES0809
the problem started a week ago, vehicle started losing power. i replaced all the plugs and wires, along with the distributor cap and rotor. i also cleaned the PCV valve, the vehicle still shudders and has no power once in gear, it acts as though it is a two cylinder engine, i have also run seafoam in the gas tank, the fuel pump and filter have been replaced.
Sep 16, 2019 at 4:45 AM
Good afternoon.
The first thing I would do is remove the spark plugs and do a compression test to verify there is no internal damage to the motor.
Sep 16, 2019 at 5:34 AM
