1995 Ford Aspire Running w/o power
80,000 MILES • 4 CYL • FWD • AUTOMATIC
DAGO318
My car, at times runs in a way that it looks as if it has no powere. Then other times it runs great. I have noticed when the weather is hot and muggy, the car runs w/o powere. When the weather is a little cooler, or humidity is low, it runs fine. I was thinking the oxygen sensor. what do you think? I would also like to note that when the car runs w/o power, the "check engine" light comes on.
May 16, 2008 at 12:42 AM
ALFLORES
  • 6 POSTS
try to scan your engine when the check engine light comes on.you could go to an autoparts and loan a scanner for free,with the no. code is gonna be 95% easier to find your problem.ps using the scanner is pretty easy just follow the question and your gonna be set. [quote:3aaff2ec04="dago318"]Engine Performance problem
1995 Ford Aspire 4 cyl Front Wheel Drive Automatic 80000 miles
My car, at times runs in a way that it looks as if it has no powere. Then other times it runs great. I have noticed when the weather is hot and muggy, the car runs w/o powere. When the weather is a little cooler, or humidity is low, it runs fine. I was thinking the oxygen sensor. what do you think? I would also like to note that when the car runs w/o power, the "check engine" light comes on.[/quote:3aaff2ec04]
May 17, 2008 at 1:26 PM
