1995 Ford Aspire Engine cranks will not Fire
1995 FORD ASPIRE
119,000 MILES • 4 CYL • FWD • AUTOMATIC
ELBO55
I have replaced the distributor from a running engine of the same model vehicle.
1995 Aspire will crank but will not fire
Sep 22, 2008 at 11:54 AM
Do below and tell me what happened
Get a carb cleaner and spray into the carb or the throttle body on an EFI. Did it start and die? If not disconnect a sparkplug wire or 2 and ground it to the engine -have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel problem, check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs,distributor pick-up coil, ignition control module, cam and crank sensors-
Sep 24, 2008 at 4:59 PM
1996ASPIRE
I'm having the same problem the above user has.. I changed mine from auto to a manual when the aut tranny went out.
If it's not getting spark how do you locate the distributor pick-up coil, ignition control module, cam and crank sensors? The thing about my car is that after a long time of trying to crank it will start and then when I turn it off and back on it just turns over again.
Oct 12, 2008 at 10:07 PM
