Knock sensor 2 circuit High Voltage
150,000 MILES • 3.6L • V6 • 2WD • AUTOMATIC
JOE WRIGHT2
  • 81 POSTS
Replaced starter, had to remove knock sensor to do that.
Reinstalled and plugged back in, now getting check engine, with above code.
Removed sensor again, (had to remove cat pipe again, ughh)
There is no ohm reading at the sensor terminal, should there be?
How do I check the wiring, and what do I look for?
What terminals at the ecu is that sensor located?
I ordered a new sensor, for today. But if it’s a wiring problem, how do I troubleshoot it
Thanks, Joe
Apr 25, 2023 at 11:58 PM
STEVE W.
  • 15,423 POSTS
Glad to hear you found it. Thanks for the update.
Apr 29, 2023 at 8:06 PM
