2002 Kia Sportage
THIBEAULT
  • 2002 KIA SPORTAGE
  • 4 CYL
  • 4WD
  • MANUAL
  • 170,000 MILES
While driving car died and won't start. Engine turns over but won't fire and start. Changed fuel pump.
Sunday, January 3rd, 2010 AT 11:12 AM
Cranks and w/n start
Get a helper disconnect a sparkplug wire or 2 and ground it to the engine at least 3/16 away from ground -have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel related problem, check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs, coil's resistances, distributor pick-up coil, ignition control module, cam and crank sensors and computer Note: If it doesn't apply disregard it
Monday, January 4th, 2010 AT 1:00 AM
