2004 Kia Sorento Coolant Leak
TJRYAN
  • 2004 KIA SORENTO
Engine Cooling problem
2004 Kia Sorento 6 cyl Four Wheel Drive Automatic
Never had a problem before today. Noticed that I have a coolant leak appearing at the driver's side. Engine isn't running hot. Could this just be a problem with the upper hose or do I have bigger issues?
Thursday, September 24th, 2009 AT 10:11 AM
  • 110,182 POSTS
If it's on the driver's side, chances are it is a hose. They make a pump to pressurize the system to check for leaks. I would recommend renting the pump at a local parts store (some will just lend them) and pressurize the system to see if you can identify where the leak is coming from.
Let me know what you find.
Tuesday, October 13th, 2009 AT 8:50 AM
