1994 Kia Sephia shakes and dosent start
LORANDPA
  • 1994 KIA SEPHIA
  • 4 CYL
  • FWD
  • MANUAL
  • 110,000 MILES
Hi I have a kia Sephia from 1994, everything works well, but sometimes I have a problem starting the car, basically I try to started and it trys to start but dosent turn on, then if I press the gas pedal starts but seams to go in 2 or 3 pistons it shakes and some black smokes come out, if I gas a little bit more it goes well, same happens when I drive starts to shake and dosent have power, also sometimes smells of fuel in car.
I change the sparks, for me is like dosent get fuel, I am not sure.
Friday, September 18th, 2009 AT 6:23 AM
  • 110,182 POSTS
If you see black smoke, that means the engine is getting too much gas. It's running rich. Has the check engine light come on? It could be a bad ambient temp sensor, but I need to know if there is a code.
Tuesday, October 13th, 2009 AT 7:20 AM
