2005 Kia Sedona cruise control
JTENNANT
  • 2005 KIA SEDONA
  • 6 CYL
  • FWD
  • 74,000 MILES
Where is cruise control located in engine compartment?
Tuesday, April 7th, 2009 AT 7:00 AM
DAVE H
  • 13,384 POSTS
CRUISE CONTROL
Cruise control system is engaged by "CRUISE" main switch located on center instrument panel, right of steering wheel. System has the capability to cruise, coast, resume speed, and accelerate, and raise "tap-up" or lower "tap-down" set speed. It also has a safety interrupt, engaged upon depressing brake or shifting select lever.
Stepper Motor Cruise Control (SMCC x.5) is a speed control system that maintains a required vehicle speed at normal driving conditions.
The main components of SMCC system are mode control switches, transaxle range switch, brake switch, vehicle speed sensor, cruise control module and control cable that connect throttle body.
SMCC system uses a cruise control module to gain the required vehicle cruise operation. Two important components of the module are an electronic controller and a electric stepper motor.
The controller monitors vehicle speed and operates the electric stepper motor. The motor moves a ribbon and throttle linkage, in response to controller, to maintain the desired cruise speed. The cruise control module contains a low speed limit which will prevent system engagement below a minimum speed of 40Km/h (25mph). The operation of the controller is controlled by mode control switches located on steering wheel.
Transaxle range switch and brake switch are provided to disengage the cruise control system. The switches are on brake pedal bracket and transaxle. When the brake pedal depressed or select lever shifted, the cruise control system is electrically disengaged and the throttle is returned to the idle position.
CRUISE MAIN SWITCH
Tuesday, April 7th, 2009 AT 6:15 PM
