2004 Kia Optima Won't Start
10,000 MILES • 6 CYL • FWD • AUTOMATIC
WVAHASHER
When I stopped my 2004 Kia to go into the store, and came back out it wouldn't start.
The engine won't turn over. When you turn over the ignition, it turns for a short one second weak 1/2 turn, nothing else...
The battery is only a month old.
The battery terminals seem to be clean and tight. With the headlights on, and you try to start it, they go out.
I'm also having trouble locating the starter...
Jul 11, 2008 at 10:29 AM
  • 75,988 POSTS
Get the battery and alternator load tested-double check all connections leading to and from the battery and alternator-also check for excessive parastic draw on the electrical system before we get into the start circuit
Jul 11, 2008 at 10:48 AM
WVAHASHER
can you tell me where the starter is located?
Jul 11, 2008 at 11:53 PM
WVAHASHER
The timing belt has been replaced twice in thie vehicle. Could it be the timing belt again?
Jul 11, 2008 at 11:55 PM
  • 75,988 POSTS
Not familiar with your vehicle but start at the battery positive terminal/cable follow it till it dead ends on the battery terminal of the starter
Jul 12, 2008 at 1:29 AM
