1999 Jeep Wrangler Check Engine Light
HFRICK
1999 Jeep Wrangler Sport; 6cyl; A/C; Automatic
75K miles on odometer; engine rebuilt @ 50K after throwing a rod
No odd sounds (that's weird, heh?); some leakage from xfr case
Question: How to reset the "Check Engine" light? I replaced the thermostat and the serpentine belt. In my haste, I cranked the engine up to check for coolant leaks BEFORE INSTALLING THE NEW SERPENTINE BELT (Dang it). Might have run 30 seconds before I realized what I'd done. Now the Check Engine light stays on ... I think because some kind of failure code was set in the computer. Am I right and is it an easy thing to reset?
Sep 11, 2007 at 8:27 AM
  • 75,988 POSTS
[quote:6c74b85702="hfrick"]1999 Jeep Wrangler Sport; 6cyl; A/C; Automatic
Question: How to reset the "Check Engine" light? I replaced the thermostat and the serpentine belt. In my haste, I cranked the engine up to check for coolant leaks BEFORE INSTALLING THE NEW SERPENTINE BELT (Dang it). Might have run 30 seconds before I realized what I'd done. Now the Check Engine light stays on ... I think because some kind of failure code was set in the computer. Am I right and is it an easy thing to reset?[/quote:6c74b85702]
If you have an Autozone within the area bring it in its a freebie service. Perhaps it needs a computer relearning. It takes a scan tool to clear the CEL/MIL/SES
Sep 11, 2007 at 8:39 AM
MERLIN2021
  • 17,250 POSTS
If it was my Jeep i would go to Autozone or really any parts store today, and get the codes read, write em down, and they can reset the MIL for you! They usually do this free...
Sep 11, 2007 at 8:40 AM
HFRICK
Much thanks, my friends.
Sep 11, 2007 at 9:02 AM
HFRICK
One more data point. When I went to take it to Autozone, the warning had apparently reset itself. Bulb test goes at start-up. Then light turns off. I'm assuming that I finally cycled the engine enough times with the serpentine belt installed that the computer concluded there was not a problem after all.
Sep 12, 2007 at 5:08 AM
Suggested Repair
Have the codes read and the check engine light cleared with a scan tool at a parts store, often at no charge. With the serpentine belt installed and no remaining fault, the light may also clear itself after several drive cycles.
Conversation Summary
A 1999 Jeep Wrangler owner asked how to reset a check engine light that stayed on after the engine was briefly run without the new serpentine belt installed. Experts recommended a free code read and MIL reset at AutoZone or another parts store, noting a scan tool is required and the computer may need to relearn. The owner later reported the light had cleared on its own after enough running with the belt installed.
