check engine light on
JEEP WRANGLER
JACKIE2799
  • 5 POSTS
I am wondering if there is an egr valve on a 2001 jeep wrangler 4.0 ltr? I get a p0300 code and sometimes a rough idle. when I shut the engine off to retrieve the fault code and restart the engine it runs fine.
Feb 18, 2007 at 1:55 PM
CHEVY22
  • 1,375 POSTS
a p0 300 is a random misfire code , not the egr , i would start simple , how long since a tune up ??? plugs cap rotor and wires
jim
Feb 18, 2007 at 2:04 PM
JACKIE2799
  • 5 POSTS
Within 2000 miles I have done spark plugs,crank sensor,distributor sensor,fuel pump,coil pack,and main printed circuit board according to jeep factory mechanics.My last jeep recommendation was to do a valve job.I believe this would give a specific cylinder code and would not reset by turning the engine off and restarting. the condition happens at around 3000 rpm at highway speedsof 60 - 70 mph. I get a code p0300 and engine runs rough.I suspect emission controls
Feb 19, 2007 at 10:22 AM
CHEVY22
  • 1,375 POSTS
ok , have you checked the fuel pressure yet ???
spec is 44-54 while idling
there are many things that will cause this problem , if fuel pressure checks out , check compression
Feb 19, 2007 at 10:26 AM
JACKIE2799
  • 5 POSTS
I ave checked fuel pressure at jeep I am told it was within specs. and if compression was bad wouldnt it give individual cylinder code?
Feb 19, 2007 at 10:43 AM
CHEVY22
  • 1,375 POSTS
not necessarily if two cylinders were low it would kick the 300 , there is so many test you could do ,im not sure if you have the tools or even want to check lmk
Feb 19, 2007 at 10:48 AM
JACKIE2799
  • 5 POSTS
I have checked compression on all six cylinders within specs .when i get the fault and missing occurs I shut off the engine for ten seconds and restart the missing stops like it resets something electrical. thank you for the info!!!
Feb 20, 2007 at 8:47 AM
CHEVY22
  • 1,375 POSTS
may not be it but , ive seen the injector harnesses pull apart, do a wire shake test at the injectors , theone i found was at #2 on the injector plug, trying to help but not seeing it do it is tough , for this kind of problem anyway
Feb 20, 2007 at 8:53 AM
JACKIE2799
  • 5 POSTS
Itried the wiggle test at 3000 rpm could not make unit fail.I have noticed that when the engine light starts flashing at highway speed if I accelerate the light will go out and usually comes on when decelerating thanks again.
Feb 20, 2007 at 9:06 AM
