Hi mdantel, Welcome to 2carpros and TY for the donation
No power to PCM, no check engine light,
Check and test fuse no. 6 30amp and fuse no.10 10amp
No.6 is the battery power to the PCM and no.10 to the CEL
I can't get the ASD relay to click when ignition switch is turned on-Could be the computer control of the ASD relay circuit-not grounding the relay
SPONSORED LINKS
Friday, August 13th, 2010 AT 10:38 PM
