2001 Jeep Wrangler Check engine light
71,935 MILES • 6 CYL • 4WD • MANUAL
PWC222
My check engine light came on, how do I reset it?
May 17, 2008 at 2:54 AM
MERLIN2021
  • 17,250 POSTS
First thing you need to do is have the codes read, Autozone does it free, Post the results with the code number(s). Even if the service engine light is not on, there should be freeze frame data stored.
If it won't make it to Autozone, buy a cheap scanner, they can be had for 30-40 dollars, a good investment, since they cover all cars sold in the USA from 96 on...you want to know why it's on b4 you reset it!
May 17, 2008 at 2:58 AM
