Charging System
RJP56
I have a 1999 Jeep Wrangler 4 cyl, standard with 80,000 miles on it. The vehicle has a dead short to ground which is I believe is taking my alternator out. After looking, it's not in any of the fused cuircuts. I checked all the grounds, they look good also. The second alternator is putting out 18.5-19 volts. All the gauges on the dash also drop as I rev up the engine and return to normal when idling. Any ideas?
Sep 17, 2007 at 6:41 AM
  • 75,988 POSTS
[quote:01cb6b15e3="rjp56"]I have a 1999 Jeep Wrangler 4 cyl, standard with 80,000 miles on it. The vehicle has a dead short to ground which is I believe is taking my alternator out. After looking, it's not in any of the fused cuircuts. I checked all the grounds, they look good also. The second alternator is putting out 18.5-19 volts. All the gauges on the dash also drop as I rev up the engine and return to normal when idling. Any ideas?[/quote:01cb6b15e3]
Your voltages are too high its over reconditioning the battery its killing it. about the dead short entirely remove all wiring at alternator-dead short diasappears you have a bad alty-
Sep 17, 2007 at 7:04 AM
