1994 Jeep Wrangler Dead After Jump Start
SUVECK
Yea I once again left my lights on and drained my battery on my 1994 jeep wrangler. I went to go jump start it like I always do except this time something went wrong. I accidently contected the positive to the postive and the negative to the negative on both cars. Needless the say when I tryied to start my car smoke started pouring out my fuse box. I checked all the fuses they seem fine but everthing is completly dead. I know I mess up my electrical system pretty good I was wondering if you have any idea to the extent of the damage I might of caused?
Mar 14, 2006 at 12:35 PM
JPAM
  • 307 POSTS
well i guess i would start of with a good battery and work my way back from battey.... check your fuseable links good chance that they are taste..
well good luck and let us know whats going on.. thanks jess s.
Mar 17, 2006 at 6:51 PM
Suggested Repair
Start with a known-good battery and work back from the battery. Check the fusible links, which are likely burned open after the jump-start incident.
Conversation Summary
The owner of a 1994 Jeep Wrangler drained the battery by leaving the lights on. During a jump start, smoke came from the fuse box and the vehicle went completely dead, though the fuses looked intact. The expert advised starting with a good battery and checking the fusible links, which are likely damaged.
